Hi, I’m trying to show nm-applet in my fvwm. I found that I need a system tray (do you confirm?).
I found stalonetray that needs KDE.
Would you mind suggesting me another way or another simple system tray to achieve this behaviour?
Thanks bye
I was not aware stalonetray needed kde, but not surprised
The only other one I heard of is trayer
http://github.com/sargon/trayer-srg
which seems to require gktk2
what distribution do you use? Under Debiann no dependency to KDE exists. Also on Arch, Gentoo or Fedora.
I’ve tested all available trayers under FVWM but stalonetray is the only one which works with all applications wants to be sit in the tray.
– Thomas –
I also tried more than one tray in fvwm. And i returned back to stalonetray with this ~/.stalonetrayrc
transparent false
no_shrink true
sticky false
#fuzzy_edges 0
tint_level 0
tint_color white
#log_level info
parent_bg true
icon_gravity NW
dockapp_mode none
icon_size 18
sticky true
window_layer top
window_strut none
window_type normal
max_geometry 6x1
geometry 6x1
bye scientific
