EdgeScroll 0 0
EdgeResistance 10000 100
Mouse 1 TS A Move-or-Raise
Mouse 1 WI M Move-or-Raise
AddToFunc Move-or-Raise
+ "M" Move
+ "I" Raise
If I am not pressing the meta key when I drag on the titlebar of a window then it obeys EdgeResistance. However if I drag from the title with the meta key or inside the window with the meta key there’s not resistance when I cross between desktops.
I’ve done a bunch of searching and read the docs but haven’t found a solution to this.
hmm… I must not be understanding the original post.
With EdgeResistance 10000 100 it will not move between pages on my system if I am moving a window - alt or not.
Are you saying it should with the above function, or should not?
If you are saying it should move across pages - which is how I originally interpretted the post - then why does it? It does not on mine, which is what I would expect based on the function and mouse/key bindings.
