I’ve made an application with various windows. There are different priority concerning the windows, and one of this must always be on the back.
Others windows may always be on top… etc.
When my application run under Gnome or KDE environnement, windows priority work very well.
But when it runs under FVWM, there are no more windows priority manage. Each time I click on a title of a window, the window is put on the top, even if it must stay on the back.
Does anybody can help me to force the behavior of my windows?
You’re not wrong, but you should probably use the “Layer” stle-command for this, to really make sure it does stay on bottom. If an application is unusually particular about its layer, it’s probably an abnormality with the hint set for the window.
