hello everyone:
I have known, if I use
AddToMenu “test”
“windows list” WindowList
I will have to press the menu item to popup the window list.
But I want to window list can show up as a normal submenu. That’s to say when mouse is on the menu item the submenu of window list popup.
Can anyone tell me how to do it?
pipehappy:
hello everyone:
AddToMenu “test”
You can’t do it directly (that’s why there’s the ‘FvwmWindowMenu’ module, the ‘WindowList’ isn’t a menu per se). You could always approximate it with something like:
DestroyMenu test
AddToMenu "test"
+ MissingSubMenuFunction foo
+ "WindowList" Popup Nop
DestroyFunc foo
AddToFunc foo I WindowList
… but that’s ugly. Look into FvwmWindowMenu.
thomasadam:
pipehappy:
hello everyone:
AddToMenu “test”
DestroyMenu test
AddToMenu "test"
DestroyFunc foo
oh, you know it. That’s ugly but it can work
It does work, it just depends whether it meets your needs or not.
