Hi guys,
this screen shot should speak for itself - I see the xosview monitors initialising on startup and then getting swallowed in the shelf but the display is poor and I don’t know how to go about configuring the font size or settings so that it looks the way it should in taviso’s screenshots.
as you can see from the other items I am struggling to get the icons working despite downloading and including in my path the tar.gz pointed to in taviso’s latest beta config download thread… I suspect that something is not being found and default text is being dumped in a cramped space…
if anyone can recognise the problem I would appreciate some help - otherwise I will continue to search and climb the learning curve!
Will
It’s a setting with your XServer’s font DPI in /etc/X11/xorg.conf – try changing the order of the font lines (swapping 75dpi over for 100dpi) – the order they’re listed in is the order they’re searched in.
You should also check to see what the -dpi value is when it is passed to the XServer as it starts up – it’s in a file in /etc/X11 somewhere.
Thanks ThomasAdam,
I have done as you recommend and made this change to the beginning of my xorg.conf
Section "Files"
FontPath "/usr/share/X11/fonts/misc"
## FontPath "/usr/share/X11/fonts/cyrillic"
FontPath "/usr/share/X11/fonts/75dpi/:unscaled"
FontPath "/usr/share/X11/fonts/100dpi/:unscaled"
FontPath "/usr/share/X11/fonts/Type1"
FontPath "/usr/share/X11/fonts/CID"
FontPath "/usr/share/X11/fonts/75dpi"
FontPath "/usr/share/X11/fonts/100dpi"
# paths to defoma fonts
but this has not helped so I found:
XOsview in app-defaults
! ** DO NOT EDIT Xdefaults!!!!
! ** Only make changes to the file Xdefaults.in, and re-run ./configure
! ** to regenerate Xdefaults.
! ** Thanks,
! ** the Management :) (bgrayson)
! xosview resources (override into your .Xdefaults file)
! $Id$
! General Resources
!xosview*title:
!xosview*geometry: +5+5
!xosview*display:
xosview*captions: True
xosview*labels: True
xosview*transparent: False
xosview*meterLabelColor: wheat
xosview*usedlabels: True
xosview*usedLabelColor: wheat
xosview*borderwidth: 0
xosview*font: 7x13bold
xosview*background: navy
xosview*foreground: wheat
xosview*enableStipple: False ! Change to true to try beta stipple support.
xosview*samplesPerSec: 10 ! not yet supported
xosview*graphNumCols: 128 ! number of samples shown in a graph
and I tried changing the 7x13bold to some other values despite the warning not to edit manually - I must read up on the process of reconfiguring with ./configure and how to specify Xdefaults.in - all new to me. I suspect this is the file you are refering to. Thanks for the pointers.
Will
You can also put something along the lines of
Xft.dpi: 96
in ~/.Xdefaults which is what worked for me
Nothing to do with ./configure. If you change ~/.Xdefaults whilst you’re still in X, just run:
xrdb -merge ~/.Xdefaults
