I recently upgraded to fvwm 2.6.5 from Macports. When I iconize xterm in addition to the title I also get mini xterm picture. That is inconvenient since takes space, especially if you work with multiple windows. How to prevent this behavior and just have icon name. My entry in .fvwm2rc
is
Style “XTerm” IconBox 100x1000-10+400,
IconGrid 25 40, IconFill right top \
On FreeBSD, it is very easy to change any build options because of ports tree,
it takes only few seconds to add or remove some configure flags via Makefile,
in result you don’t need to add any additional flags to xterm, so it is more preferable way for me.
P.S.: Please, disable image resolution limit! It is very annoying! FVWM is such a nice window manager, so screenshots on forum pages would look beautifully!
P.P.S.: It is also possible to disable xterm active icons via [color=green]~/.Xdefaults:
