This collection is inspired by the Gnome Extensions that make Gnome multifunctional. This gave the name “FVWN myExtentions”. With the new FVWM3, it started as an experiment similar to what I did in 2005 ( ArchWD-FVWM ) which was complex and running on root system files. With myExt, it is easier to work and manage by using the default FVWM3 config as a base and directly in ~/.fvwm. The config is split into folders and runs in the same sequence as the original. The additional extensions are simply added in associated folders.
- 1Functions
- 2-3Styles
- 4Menus
- 5Bindings
- 6Decor
- 7Modules
Besides the fast and low memory usage of FVWM, the aim is to speed up the workflow on common tasks and a clean desk. Access to choices and customization. This structure helps to maintain and create new functions, decors, and modules.
Config setup and download are posted in MX Linux, please click here.
